doing coolant swap. gotta ?
Old Mar 11, 2010 | 09:15 AM
Are are you wanting to change out? Stay with the Dexcool and Distilled water cause one way or the other you will need to flush the system every 2 years so go with what Rover calls for.
Old Mar 11, 2010 | 10:11 AM
sloppyjoe's Avatar
mike, i just stayed with dex.
i flushed with water 5 times and still had a tinge of orange to it. and i am so **** that if i think there is a drop of old dexcool in with new green stuff then i will be uneased.
so i flushed. filled with a gallon of dexcool and topped off with distilled. ran and bleed/ burped the system.
in the mix of all this i swapped the thermostat and tried to remove to stupid plastic shield but i will need a dremel to cut it out.
painted 2 wheels black and cleaned up all the wire connections that got water and antifreeze on them.
checked the oil etc etc etc.
lubed the shafts and joints.
tonight while i paint the other 2 wheels i will also be cleaning and conditioning the leather.
Old Mar 12, 2010 | 09:48 AM
Make sure to recheck the coolant level 2 times over the next week, when stone cold and make sure you are filled to the cap, not the lines on the bottle.
Old Mar 12, 2010 | 11:18 AM
sloppyjoe's Avatar
refilled last night to cap before turning the truck around in the garage to take the other wheels off. will look again tonight after work then actually drive it. i am hoping for no waterfalls
Old Mar 12, 2010 | 12:52 PM
hilltoppersx's Avatar
go go jason waterfalls
Old Mar 12, 2010 | 02:23 PM
Pipedream's Avatar
If you are pulling the belly pan out, I had to pull the steering dampner and drag link off, not too bad coming off but the draglink ends just spin unless you get a torx inside
nuclearw
Aug 5, 2013 08:05 PM
bantham1
Jul 20, 2011 01:51 PM
RoverRookie
Jul 27, 2009 09:07 PM
tornado_735
May 3, 2009 06:39 PM
Smorgan2004
Jun 4, 2007 04:58 PM
