Doing Heads, what else?
Going to be doing a Head gasket rebuild, What else should I replace while im in there?
This is what I have so far. Head gasket kit, coilpack ,waterpump, timing chain kit, oil pump gears, machinists straight edge, feeler gauges (check for warping) what else am I forgetting?
I'm not pulling motor, doing in vehicle
Things I did on mine during the HG job recently (aside from what you've already mentioned)
radiator
all hoses
180 degree thermostat
crank sensor (was easier to get to so I figured why not)
upper intake gasket
TB heater kit/TB gasket
crank seal
front cover gasket
oil pan gasket
pickup tube o-ring
oil filter adapter o-ring
oil separator
exhaust manifold outlet studs/nuts and outlet gaskets
head bolts (I'm sure you already know to replace these)
condenser fan motor
plus quite a few other things not really related to the job at hand, so I won't get into those.
radiator
all hoses
upper intake gasket
crank seal
front cover gasket
oil pan gasket
pickup tube o-ring
oil separator
condenser fan motor
- Thread chasers to clean bolts and threads in block (you can get a loaner kit form Auto Zone)
- Thread sealant for bolts that go into the water jacket
- Loctite (certain bolts need it, Oil pump bolts)
- 180 deg Thermostat
- check/replace idler pulleys/bearings
Make sure that you have a 8mm or 5/16" 12 pt socket for the valve cover bolts
Also a few cans of brake cleaner for keeping everything sterile.
