Done with the LAST build…
Old Dec 31, 2025 | 11:24 PM
Frank4's Avatar
Well done man. I know it’s been a while since you bought the long block but do you mind sharing how much it set you back? I see one of these in my future.
Old Jan 1, 2026 | 04:18 AM
Bone9's Avatar
Originally Posted by Tony Luna
Pretty straight forward. Meziere in line t-stat assembly, 180F GM t-stat, and some 90 degree radiator hoser. There's an old write up on here with instructions and pics.
The trick part it the aluminum "T" from CARS4X4 (also have the aluminum multi hose adapter that sits next to the water pump) that I modified for a mechanical water temp gauge - https://landroverforums.com/forum/di...estion-100877/
awesome thanks. Was it worth doing? How does it perform?
Old Jan 2, 2026 | 03:55 PM
Tony Luna's Avatar
All in w shipping and a few add ons - just over $10K. Barely over a year of daily driving and it puts a smile on my face every time it fires up. ECU upgrade is a must have. Couldn’t be happier w TWS.
Old Jan 2, 2026 | 03:59 PM
Tony Luna's Avatar
Absolutely! But then again, I’ve modded just about everything I’ve ever owned... Works great. Instant oil pressure reading and I can actually see the motor temp rising gradually.
Old Jan 2, 2026 | 04:03 PM
Bone9's Avatar
Ha ha me too! I'm mainly talking about the coolant temps. Do you get any fault codes?
Old Jan 3, 2026 | 02:48 AM
Tony Luna's Avatar
The original temp sensor and gauge on the instrument cluster are still there. No fault codes.
Old Jan 3, 2026 | 02:58 AM
Bone9's Avatar
I meant low coolant temperature fault codes from the inline thermostat mod.
Old Jan 3, 2026 | 12:28 PM
Tony Luna's Avatar
Got it. No codes. 180 degree t-stat. Typically runs between 183 and 194. Newer radiator and Flowkooler water pump.
The Deputy
16
Oct 19, 2025 10:41 AM
Lnberger
Apr 22, 2025 09:34 PM
N E WHR
May 2, 2021 09:41 PM
dmannrover
Jul 31, 2019 11:57 AM
