Door Actuator Lock Replacement
Old Dec 7, 2019 | 11:07 AM
cvhyatt's Avatar
Default Door Actuator Lock Replacement
I hate this kind of thing because I usually screw it up. Searching around youtube I found this guy who did a pretty good video (I think) of how to replace the actuator. Before I head down this path, I just thought I would share this with folks to see if anyone had any commentary before I got started.
Old Dec 7, 2019 | 03:38 PM
Extinct's Avatar
Good video, not a hard job, not really any "watchouts". While you are in there be sure to lube the window tracks liberally with heavy wheel bearing grease.
Old Dec 7, 2019 | 06:19 PM
keninnc's Avatar
Take note of where the plastic clip is on the rod that hangs down from the door handle and where it attached onto the actuator. Easier if you remember where it was (low or high) for reassembly.
Old Dec 10, 2019 | 07:01 AM
DonaldGrace's Avatar
Youtube is also a better option before hiring any locksmith for your work.
Old May 22, 2020 | 07:09 AM
SophieTracy's Avatar
To understand the concept of lower and upper assembling, you need to talk to the locksmith expert about it.
sayeedA
Oct 16, 2018 01:56 PM
Brad S1
Jan 23, 2018 09:02 AM
FRLNDR
Freelander
Jan 13, 2016 04:25 PM
NiteTrain
Oct 4, 2012 06:41 PM
llPANCHOll
Aug 21, 2009 09:18 PM
