door lock actuator
Old Apr 6, 2008 | 07:12 PM
Default door lock actuator
Ok, my drivers door lock actuator was acting up, you would hit the lock button on the remote and all doors would lock except the drivers door.
If you used the key it was hard to turn but would lock.
So today I popped the door panel off and cut a slit in the plastic liner to expose the actuator.
Peeled back the rubber boot, sprayed my favorite penatrant/lube and locked the door a couple of times, taped up the plastic liner and put the panel back on, works like new.
How long will it last? I do not know, but hey, if it lasts six months its worth it.
Total time, under 30 min.
Old Apr 8, 2008 | 01:30 AM
N.Franklin's Avatar
Default RE: door lock actuator
Ive got a similar issue with my back door, when you press the unlock button on the key fob it goes up and back down again, if you use the key to unlock it the door still will not open. Gonna jump the seats and try to fix it through the subwoofer hole sometime this week, Ill post up what I find to be the issue.
Old Apr 8, 2008 | 08:25 AM
Darover's Avatar
Hey thanks for the tip Spike, I'll try it sometime this week. My driver's door just started doing this this week. And it went without warning. It use to open and close on the first push of the button. Then last week-end it just decided to stop working period. You can hear the actuator knocking,clunking,tocking or however you wanna describe the noise.....when pushing the button, but the **** won't move.
The more I write ...the more this gets me thinking...not sure what you drive, but will this work on a D2 ??? and I remember reading about a little spring that is known to let go on actuators ???
Old Apr 8, 2008 | 04:43 PM
Mine is a DI so I do not know if this will work on a DII. Once you get the door panel off it is pretty simple and no need to remove anything, just cut the plastic so that you can peel back the rubber boot.
If you go to a NAPA and get a "body spoon" it makes it real easy to remove the door panel. It is a wide curved puddy knife kind of thing designed for just such a purpose.
A little lube never hurt, right?
Old Apr 8, 2008 | 04:45 PM
ORIGINAL: N.Franklin
I have heard of this happening before and do not know how to fix it. Did you pop the emblem off the back door and spray the latch really good? That needs to be done every couple of months, more so here in the north with snow and road salt.
Old Apr 8, 2008 | 08:48 PM
Darover's Avatar
I have a door panel remover if that's what your talking about. I'll look into it this week and let you know how it went.
Old Apr 8, 2008 | 09:03 PM
Yeah I dont know the name of the tool, its my dads and he used to work at a body shop like 400 years ago. He calls it a body spoon, but who knows.
Keep me posted on how it turns out.
Old Apr 10, 2008 | 12:26 AM
N.Franklin's Avatar
ORIGINAL: Spike555
Havent tried that yet, but will try it before doing surgery. Seems like these trucks are bi-polar, one month they run smooth as butter, the next month they spend your paycheck for you. Hopefully this is an easy fix and I dont have to buy anything.
Old Apr 10, 2008 | 07:57 AM
Darover's Avatar
[:@]didn't work[:@]I even took it out, opened it up and sprayed it with lube, then triedwhite lithium grease. Nothing worked. So I'll be getting another one soon. At least it's the driver's door and I can still use the key.
Old Apr 10, 2008 | 03:36 PM
It was worth a shot. If it had worked it would have saved you some money, but hey, what ya gonna do?
