door lock actuator
door lock actuator
Ok, my drivers door lock actuator was acting up, you would hit the lock button on the remote and all doors would lock except the drivers door.
If you used the key it was hard to turn but would lock.
So today I popped the door panel off and cut a slit in the plastic liner to expose the actuator.
Peeled back the rubber boot, sprayed my favorite penatrant/lube and locked the door a couple of times, taped up the plastic liner and put the panel back on, works like new.
How long will it last? I do not know, but hey, if it lasts six months its worth it.
Total time, under 30 min.
RE: door lock actuator
Ive got a similar issue with my back door, when you press the unlock button on the key fob it goes up and back down again, if you use the key to unlock it the door still will not open. Gonna jump the seats and try to fix it through the subwoofer hole sometime this week, Ill post up what I find to be the issue.
on
1 Post
Hey thanks for the tip Spike, I'll try it sometime this week. My driver's door just started doing this this week. And it went without warning. It use to open and close on the first push of the button. Then last week-end it just decided to stop working period. You can hear the actuator knocking,clunking,tocking or however you wanna describe the noise.....when pushing the button, but the **** won't move.
The more I write ...the more this gets me thinking...not sure what you drive, but will this work on a D2 ??? and I remember reading about a little spring that is known to let go on actuators ???
Mine is a DI so I do not know if this will work on a DII. Once you get the door panel off it is pretty simple and no need to remove anything, just cut the plastic so that you can peel back the rubber boot.
If you go to a NAPA and get a "body spoon" it makes it real easy to remove the door panel. It is a wide curved puddy knife kind of thing designed for just such a purpose.
A little lube never hurt, right?
ORIGINAL: N.Franklin
ORIGINAL: Spike555
I have heard of this happening before and do not know how to fix it. Did you pop the emblem off the back door and spray the latch really good? That needs to be done every couple of months, more so here in the north with snow and road salt.
