door lock actuator madness
Old May 1, 2008 | 03:39 PM
motormikeyman's Avatar
8th Gear
Default door lock actuator madness
Thanks all for the help with my distributor, works great now.On toanother pickle:
As a '95 D1 with 140K on it, expecting the door locks to still work was a bit much, I guess. So I got a generic kit with new actuators and control unit. Supposedly, you just hookthe new control unitup to the two lock/unlock leads for the drivers door and it will work. But after hooking it up properly, it will either only lock, or if I reverse the wires, unlock. This is with the stock driver door lock actuator removed. Is a relay stuck somewhere? Or is the control unit toast? Or maybe by taking the drivers door actuator out of the circuit, there is no polarity switching? So confused.....
kristofferzen
Sep 10, 2015 02:11 PM
Disco2Guy
Feb 16, 2008 10:30 AM
