Door lock actuators
Door lock actuators
My 2001 D 2 has a lock issue, All the actuators are inop, I can make them all lock with key if I turn it twice to the lock position but they will not unlock. You can hear them clunk but they will not unlock. The locks have gone bad over a period of time and its a pain to deal with. The alarm sets and I have to use the key to unlock the drivers door and reach around inside to unlock the other doors. I can hear the units try to move, is this something that can be lubed? Jneil
It has been awhile, but I had similar issues with my door latch actuators.
Hope the guys that really know what's going on chime in for you. I vaguely remember that is the drivers door latch actuator is bad, it will not allow the rest of them to function properly. The drivers door latch could be the issue for it all. I did have to replace other latches as well...passenger, tailgate and now the passenger rear needs replacing.
Wait for the real experts here before throwing parts at it. They may have a test to give you
My driver's door actuator was bad. Did not move at all.
All the other locks worked find. The previous owner had all of them replaced.
I would suggest -
replacing one of your actuators and see if it works.
If so, replace the rest.
at 80xxx miles she started to replace actuators.
I replaced the front door actuator at 97xxx miles.
If you have over 110,000 and your truck is set to lock the doors automatically when you start to move, then all your actuators are probably dead.
These are all in the door latches. All built in.
I paid about $140 for the unit on line.
I can't remember who it was.
Independent shop in Boulder area charged about $160 for the actuator and about $150 or a bit more for labor.
I would suggest -
bcolins
10-02-2008 05:40 PM
