Door lock cylinder wafers
Old 07-20-2021, 02:17 PM
Sandman614's Avatar
Originally Posted by hildegardrulison
the keys are not working correctly. I have called many car dealerships, and they have failed to solve the problem. I have taken many photographs of the keys while trying to fix the problem. They are not interchangeable, as they do not fit each other. Outside of the hardware, the car works fine. The car has been stored in a garage for two years with no problems. The problem was with the software that controls the engine and transmission. The guys from d me the best solution. I am delighted with their work and the new software that they've installed.
what??
Last edited by ArmyRover; 07-21-2021 at 09:19 AM. Reason: Remove spam link in quoted text
  #32
Old 07-20-2021, 02:29 PM
ahab's Avatar
Originally Posted by Sandman614
what??
This appears to be some kind of weirdo bot-spam. Every thread that discusses lock problems has these bizarre posts from newly registered individuals with a single post count and always have a link to some locksmith's website.
  #33
Old 09-18-2023, 10:32 AM
mollusc's Avatar
Resurrecting this thread again to acknowledge its usefulness.
The barrel housing was damaged and the lock pin was broken on my new 2004, so I pulled the handle and pin off my 2003 but then had to re-key it. The photos and write-up here were invaluable!
FYI, you don't need to remove the two springs for the door handle to get the lock barrel out. Once you have the retaining clip and the plastic cover off, the barrel assembly will slide out when you insert the key.
Also, if you're really stuck and don't have a good stash of wafers handy, you can put in ones that are "close enough" and then carefully roll the whole barrel against a bench grinder with the springs and wafers installed and the key inserted. This will take off any protruding wafers and give you a smooth barrel assembly that can then go back into the housing.
The following 3 users liked this post by mollusc:
ahab (09-26-2023), Danmc (09-29-2023), whowa004 (02-21-2024)
  #34
Old 09-29-2023, 09:02 AM
Danmc's Avatar
I needed to resuscitate this old thread as well. Hoping someone will know if a key that turns the barrel left but not right indicates a wrong key (cut to chassis code) or a broken wafer or some other issue with the barrel. Someone pointed out that perhaps only top or bottom wafers are used. Perhaps its one or the other for left and right?
  #35
Old 09-29-2023, 10:26 AM
mollusc's Avatar
Does it help to wiggle the key, or insert it rotated 180 degrees? If so, it might just be that the barrel assembly is worn so there is enough play that the wafers aren't clearing the cutaways in it.
Having just had the thing open, it's not true that "only one side" is used. Each of the 8 wafers pushes outwards, and they all have to clear a corresponding cutaway.
Danmc (09-29-2023)
  #36
Old 09-29-2023, 11:38 AM
Danmc's Avatar
I tried wiggling it and flipping over many times. Sprayed penetrating oil but maybe not enough. the fact that it turns ccw suggests it might be the right key, but then I know falcons up to at least bf would lock with any key so maybe not.
  #37
Old 09-29-2023, 01:27 PM
mollusc's Avatar
Does the same key work okay in the ignition? If so, you should be able to pull the door lock and clean up the barrel so that it turns in both directions. Good opportunity to replace the door lock pin at the same time.
Danmc (09-29-2023)
  #38
Old 09-29-2023, 10:27 PM
Danmc's Avatar
The car is locked and keys stolen so don't know yet if the key works in the ignition. Cant really even remember if the ignition key that I had ever opened the door, though I think so. Would get a locksmith but the cost is $660+and insurance probably wont cover that plus genuine keys - and after talking to to all the local dealers, LRA and local landrover specialists I'm not entirely sure anyone they wont get caught out by a 20 year old car and slug me with a huge bill. Would rather open it myself and use the insurance on the keys. Also suspect the barrel is the problem now, not they key. Will go out to the farm and blow a gallon of wd40 through it, hit it with some tapping and vibrating and blow some air through. Hope its a stuck wafer.
  #39
Old 09-29-2023, 11:58 PM
Danmc's Avatar
Weird, thought I replied before but must have nerfed something. Keys and fob were stolen so can't get in yet. Trying to make sure it unlocks as insurance may not cover lots of unsuccessful locksmith attempts as well as new genuine keys, and it seems like no one is sure how these work anymore. Seems like barrel could be broken anyway with the key turning only one way. Will be doing the pin as soon as I get it open. Considering drilling it now and just getting a new door lock. But first will relube the hell out of it and try some tapping, air and vibration in case its a stuck wafer.
silar
03-03-2021 07:21 AM
kristofferzen
09-10-2015 02:11 PM
cmmoyer
08-11-2015 07:45 AM
sDot
10-01-2013 08:53 AM
meltdowndave
07-04-2010 05:13 AM
Quick Reply: Door lock cylinder wafers
