door lock mechanism sheared?
Old Sep 28, 2013 | 07:52 PM
sDot's Avatar
Default door lock mechanism sheared?
I put my key into the door lock and it only goes in half way and spins 360. I can't push it in further, would it be sheared and how would I go about fixing this?
I was in my truck and manually pushed down the door lock and then after this I started having this problem. I can't explain it.
Old Sep 29, 2013 | 08:59 AM
mln01's Avatar
I don't know about the key going only half way in, but here's my fix for it spinning 360.
Driver's door lock cylinder spins - '99 DII - DiscoWeb Message Boards
Someone is now selling the same fix on eBay for $20. What's funny about it is that if you look carefully at the pictures you can see it is made from a nail, just like mine and those of many others.
Follow customworkz on eBay Profiles
Good luck.
Old Sep 30, 2013 | 09:28 AM
sDot's Avatar
Thanks. I am going to check this out.
Soon as I think everything is working good, there is something I gotta fix.
Old Sep 30, 2013 | 02:24 PM
jfall's Avatar
Replace the door lock mechanism.
If you have working FOBS there is NO REASON to ever put a key in the door.
My key has not gone in the door for a year and a half.
Old Oct 1, 2013 | 08:53 AM
sDot's Avatar
I have no fobs. I am just worried on how much it will be to get one from the dealer and have it programmed.
I think at this point I will be better off with leaving all the doors unlocked and letting someone steal it.
caneraiser
Dec 30, 2021 09:39 PM
Snafu / Disco Fries
May 9, 2011 07:56 AM
JeremyH
May 27, 2009 02:12 AM
audiurq
Jul 1, 2007 11:52 PM
