Door Lock / Rear Wiper Electrical Issue
Old Apr 7, 2019 | 11:45 AM
NewToTheTwo's Avatar
Resolved.
Was the fuse box.. Presumably the IDM specifically.
Old Jan 22, 2020 | 07:56 PM
Thomas Alberts's Avatar
I just realized I have the same problem. The truck, a 2000 D2, is relatively new to me and when first purchased I ended up doing some work that involved removing and reinstalling the under hood fuse box and pulling out some of the RH side (it is left hand drive) wire harness. Not sure if it started after that but I started to notice that the door actuators would click when I turned off the ignition. I thought that was curious because the 1999 D2 I previously had for 10 years never did that. Then today while driving I used the door lock button and the rear wiper turned on and the engine hesitated.
Old Jan 22, 2020 | 07:58 PM
Crazy... Let us know if you replace the fuse box and the outcome.
Mine has been perfect ever since.
Old Jan 22, 2020 | 08:12 PM
Yeah, maybe I'll try that. I've been using my 99 as a parts donor so maybe I'll try it and get back to you.
Old Feb 16, 2020 | 09:55 PM
Replacing the passenger compartment fuse box did fix the problem for me too. Also seems to have eliminated an intermittent DTC "Brake Light Relay Open Circuit" that caused the Hill Descent warning light to come on now and then. This DTC is also associated with that fuse box and people have reported eliminating it this same way. Thanks NewToTheTwo!
Degsy
Jan 21, 2018 04:06 AM
coors
Jan 5, 2015 10:23 PM
Drock360
Dec 10, 2013 05:04 PM
tweakrover
Jun 8, 2009 10:39 PM
CandiMan
Nov 27, 2008 08:38 PM
