door locks and radio
my d2 has had one door(rear passenger) that intermittently quits working. when i hit the dash button or the alarm it didn't react at all for a week or so. then weather here got cool and rainy and it just worked this weekend, bright and sunny today no worky! not to say the weather or temps are effecting it? it was just the only pattern I noticed with when it works and when it doesn't. do I just have a short, or does the control have cracked solder that works sometimes or not others, or am I just nuts?
as far as the radio goes the back lighting flickers sometimes, but only if the headlights are on, and if I give it the classic tv set whack on top of the dash it works right for a couple seconds. Loose connection? bad ground?
I know both of theseare simple and I could find them if I just start tearing into the truck, but I figured since these all suffer from the same illnesses I thought i should just accumulate some info before unbolting door panels and dash boards
mantle33
05-12-2010 11:23 PM
clockmaker21
01-07-2010 09:20 AM
