Door locks stopped working
Does your key work in the door?
if key works in the door then you know it’s not mechanical and it could very well be the transceiver in the headliner. When the rear sunroof leaks, water can get in it and damage it.
even if your rear sunroof is not leaking now, doesn’t mean it didn’t before
Yes, the key works in the door, when using the fob the lights blink as normal. When using the central switch I can hear the sound of it when pushing locked or unlock. Notice the clock next to is has scrambled letters sometimes. Wondering if wires are bad considering there was a rodent under the hood at one time. Just confused why it worked in the morning and then all of a sudden later does not.
