door locks stopped working
Old Sep 15, 2012 | 10:49 AM
mylesman12's Avatar
Default door locks stopped working
I've got an '04 Discovery SE and the door locks don't work anymore. I use to be able to lock and unlock the doors by pressing the key.
I just replaced the car battery with one with higher cranking amps. So its not that.
Could this be a fuse, or is there a little battery in the key itself?
Old Sep 15, 2012 | 11:32 AM
Bkreutz's Avatar
There is a battery in the key, does the little light on the key operate when you press either button? If not then I would suspect the key, if it does I'd still replace the key battery because I've seen weak batteries operate the light but not the alarm/door locks.
Old Sep 16, 2012 | 07:05 PM
mylesman12's Avatar
Key is working now, 3 doors are fine. But front passenger lock does not work by remote.
All the fuses are good, so not sure why it won't work
tsuyoi
Sep 22, 2020 10:37 AM
MrFlea1
Feb 22, 2012 08:17 PM
DiscoWest
Apr 15, 2011 08:10 PM
Tara
Aug 22, 2007 01:30 PM
jmerrill
May 17, 2006 01:18 AM
