Doors
Old Sep 21, 2008 | 01:16 PM
99LRDisc's Avatar
Default Doors
I know all about aculators, but not sure if i need new ones yet.
Pasanger front goes half down then back up, can i try lubing it or just suck it up and buy a new one? Both locks with key are stiff to open as well.
Driver door pops back open many times when i close it unless i slam hard, suggestions for this?
Old Sep 21, 2008 | 02:01 PM
Default RE: Doors
Your door latches may be out of adjustment and that is why you need to slam the door.
Lube the actuators first. If that doesnt do it then replace them.
Old Sep 21, 2008 | 02:02 PM
sdsilvere38's Avatar
Default RE: Doors
my rear lock was working yesteday and now it isn't. Think it's the same thing??
Old Sep 23, 2008 | 02:01 AM
CandiMan's Avatar
Default RE: Doors
ORIGINAL: 99LRDisc
Have you done a research about the door latch springs? From reading different post, I realize a broken latch spring can have different symptoms.When you say your RF lock goes half way down then back up, that sounds like a latch that is not keeping tension on the actuator. Which causes the actuator to pop up/down erratic.
Old Sep 23, 2008 | 02:06 AM
Urban Panzer's Avatar
Default RE: Doors
Replace the springs and all will be good
wynhd
Aug 28, 2012 11:33 PM
coloradorover
Mar 3, 2011 05:15 PM
area4us
Nov 16, 2005 07:02 PM
auburndmbfan
Aug 26, 2005 12:48 AM
toga340
Jul 16, 2004 06:08 PM
