DOT 4 or DOT 3 synthetic brake fluid?
Old Apr 18, 2008 | 12:59 PM
FJL's Avatar
FJL
Default DOT 4 or DOT 3 synthetic brake fluid?
Does it matter if you use DOT 4 or DOT 3 synthetic brake fluid? Which is best?
Old Apr 18, 2008 | 02:06 PM
Default RE: DOT 4 or DOT 3 synthetic brake fluid?
Only Dot 4 either synthetic or regular, no Dot 3, it will kill your seals.
Old Apr 18, 2008 | 10:37 PM
FJL's Avatar
FJL
thanks Mike!
Old Apr 19, 2008 | 12:31 PM
OxyCoRover's Avatar
does it matter for a disco 1 or disco 2?
Old Apr 20, 2008 | 04:21 AM
N.Franklin's Avatar
ORIGINAL: Disco Mike
Quoted for truth, I just replaced a 6 month old master cylinder due to DOT 3 fluid (father-in-law did the work while I was still in Iraq.) Use Castrol GTLMA (DOT 4), if you cant find it locally but it from british pacific or atlantic british.
Old Apr 20, 2008 | 09:44 AM
"DOT 4" only
Old Apr 20, 2008 | 11:38 AM
Phototone's Avatar
It seems that British-built cars use a different formulation of rubber on the brake seals, and DOT 3 will rot or dissolve them. This is the reason for the requirement of DOT-4. You must use DOT-4.
Old Sep 3, 2021 | 01:57 PM
petedriscoll23's Avatar
Default Rip off?
So I just took my LR3 into a shop to have my brake fluid flushed… the guy said it would be about $100 but since I have a Land Rover that takes dot 4 it’ll cost me $140… what the F? I was just at Advanced auto and dot 3 and dot 4 are the same price. Should I trust this guy or is he taking advantage of me because he heard the words Land Rover?
Old Sep 3, 2021 | 02:10 PM
Sandman614's Avatar
It's a racket.. Do it yourself
ATLDisco
Jun 6, 2012 06:21 AM
muddybuddy
Jun 4, 2009 08:50 AM
herblatham
May 1, 2008 05:57 PM
GCS1
Aug 9, 2007 07:26 AM
rangerover88
Oct 2, 2006 06:14 PM
