The dreaded front and rear sunroof!
Old Feb 1, 2021 | 03:48 PM
Chrispybacon's Avatar
Default The dreaded front and rear sunroof!
So after reading some older posts on these 2 little buggers. Mine have decided not to keep the water out!
so I'm taking the plunge and sealing up both sunroofs with sika flex and putting a clear 3m rap over them also.
Then got to tackle the sagging roof linning!
Old Feb 4, 2021 | 01:40 PM
kdscott100's Avatar
I feel your pain. I have a garvin rack on mine, so I simply put a sheet of plywood up there. So far so good........
Old Feb 4, 2021 | 02:03 PM
stillruns's Avatar
I had the wilderness rack on mine with a 1/4 in thick sheet metal floor. Never had an issue with rain as long as it was parked!
Old Feb 4, 2021 | 02:58 PM
ahab's Avatar
The sunroof gasket was never intended to seal out water. The problem is that the water passing through the gasket is supposed to be carried away by some plastic plumbing, which has failed. If you're taking down your headliner you will have the opportunity to correct this. Otherwise copious amounts of sealant will likely do the job of keeping the water out. Until they don't anymore. And that approach is difficult to reverse.
Old Feb 4, 2021 | 10:10 PM
Wheelspin's Avatar
Your so right, I’m getting a liner done now and I’ll be tracing the leak this weekend , I poured water in the sun roof drains and 1 seems to leak, I had a guy locally print 4 drain caps for 35 bucks ,and will have a go at gluing them in with epoxy , sigh I hope that fixes it .
I’d read that the whole sunroof pans stuck down with double sided tape I hope it’s not leaking there as well
Malcohmh
Sep 21, 2014 10:02 PM
Gerard
Feb 21, 2011 02:03 PM
BigRed98
Jun 21, 2010 12:30 AM
ja00disco2
Sep 21, 2009 08:24 AM
tlester72
Appearance & Camping Set Ups
Dec 28, 2007 04:12 PM
