Rear sunroof problem
Old Aug 23, 2014 | 09:47 PM
Malcohmh's Avatar
6th Gear
Default Rear sunroof problem
The rear sunroof is stuck, it only can go back, then if I'm lucky it will return but cannot go down. Both the front and rear switches click, but the rear sunroof does not move or make a sound when trying to put back into the closed position? Then it works when I click it the other way and the roof opens normally. Just trying to close it, is the problem...
Old Aug 25, 2014 | 09:04 AM
jamestfl's Avatar
you can manually close it with a 5 or 6mm hex wrench. remove plastic cover tab on the overhead plastic thingy. find correct size wrench, get wrenching. US was the only market with power sunroofs. everybody else got the hand cranks. have seen hand cranks avail at bputah.
Old Sep 21, 2014 | 10:02 PM
dnice's Avatar
I have this same problem and tried the manual cranking and it felt like something was binding underneath and made it very difficult to still close. If you have that problem then your sunroof rails may have gotten missed aligned and will require you to remove the sunroof glass (4 bolts holding glass) to realigned the rails.
BigRed98
Jun 21, 2010 12:30 AM
davidlafrance
May 23, 2010 10:53 PM
00discosd7
Dec 27, 2007 07:08 PM
compton4x4
Jan 9, 2007 09:57 PM
christer
Freelander
Oct 28, 2006 03:47 PM
