Driiveshaft Question
I think GKN makes a centering ball also and I think neapco used to make one but never had either of those to look at.
I'm probably wrong about this, and maybe someone will chime in if I am but, I don't think any centering ***** have a grease fitting on their own. I think the socket in the driveshaft that the ball goes into has to be drilled and tapped for a grease fitting and a low profile needle type fitting will have to be used to clear everything.
Iirc a 3/8 drive 9/16 socket with universal or wobble extention and a decent 12 inch racket. No need for 1/2 driv . don't even know if 1/2 will fit.they do sell a tool but it not needed
As drowssap says, you can use a wobble extension also.
Thanks for the help guys. I am going to get it off the truck and ship it back this weekend. Justin is going to honor the warranty. It has been shaking on the highway at around 70k so this must be the issue.
Nope, 617 don't have a grease fitting.
Saw this in one of the prop shaft rebuild DIY threads:
If you're using a u-joint with the zerk fitting in the valley of the cross, be sure to orient the u-joint correctly when you install it.
The hole for the fitting should be under compression by the driving yoke during normal operation, i.e., driving forward.
If you install it backwards so it's under tension, it compromises the strength of the u-joint.
Can someone explain/elaborate?
