Drilled or solid brake rotors? Bendix, Centric, or Powerstop Brand? Ceramic or Semi M
On the recommendation of another forum member, I've been looking at Rock Auto for brake rotors and brake pads, They have an ENDLESS selection,....... I'm willing to spend up to $125 for rotors and pads and there are several choices that fit that.
The have a brand of rotors and pads called Powerstop: $111 for solid (non-drilled) vented front rotors and scorched ceramic pads.
$128 for Drilled and slotted vented rotors with scorched ceramic pads.
Also have "Premium" Bendix non-drilled rotors for $35 ea and Centric "Premium" Scorched ceramic pads with shims for $18. Many more choices there , these are just the values that stood out to me.
Anyone looked at their list of rotors and pads? Any thoughts?
I need to get these ordered today, so any help is appreciated.
Brian in Austin
Brian in Austin
Drilled and slotted , are not a total waste of money, they help outgassing and keep the pads from resin glazing. They both help keep the brakes cooler, which reduces warping, keep the surface cleaner as well, and also remove the water better when wet.
The downside of drilled although they are better on the street than slotted is they will crack between the holes first. Every race car that i know of uses slotted rotors because they do pretty much the same and are less likely to crack.
More importantly is the carbon content of the rotors whether they are blanks, slotted or drilled. The higher carbon content the harder stronger the rotors. Sorry for they long write up but i do road race cars alot and know my brakes, the most important thing!
Track days and the mall days require different types of brakes.
I'm a FedEx driver, have been for many many years, I eat brakes for lunch, I've tried all the gimmicks on my vans, no difference between any of them.
They all stop the van, they all last about the same amount of time, they all produce brake dust.
Check these part number, they are by centric/stoptech.
Cheap Blanks 120.22005
High Carbon Blanks 125.22005
High carbon Slotted 126.22005SL
High Carbon Drilled 127.22005L
High Carbon Drilled and Slotted 127.22005L
The L at the end is obviously left side the 5 at the end denotes the front as changing it to a 4 will be the rear.
You are very correct. Drilled and slotted will provide pretty much cosmetics only on the street. But with a higher carbon content they will last longer.
