Drive Shaft Help...Neapco too big?
Old Jun 5, 2013 | 01:08 PM
  #21
NickAdams's Avatar
PinkyToe:
You understand perfectly. The first cap is installed, with spider, and then over seated. This allows spider to be deeply seated in cap, preserving first cap's needle bearings, and extend maximum across to seat in second cap and preserve its bearings. And previous advice about extra grease in end cap before assembly to hold bearings is good.
Old Jun 5, 2013 | 09:45 PM
  #22
pinkytoe69's Avatar
So, taping the yoke loosened the joint enough. Pushed in the ball and then on to the last 2 caps. Get first clip in, and I cant move the last cap in far enough. Then I remembered the fallen needle symptoms...literally almost shed a tear.
I guess it happened cause the joint has to be at an angle to fit the caps.
Im very excited to redo the whole joint again
Old Jun 6, 2013 | 07:05 PM
  #23
pinkytoe69's Avatar
So its a good thing I had to redo it. I snapped a needle bearing in the centering ball during the first install...dont ask. I had saved some bearings from the old ball, and they were the same size, so I tossed it in. Seems fine.
Thanks everyone for your advice!
DiscoJon
Jul 14, 2019 01:51 PM
Paul Grant
Oct 4, 2014 08:27 AM
CANAMDiscovery
Dec 16, 2012 12:23 PM
bcolins
May 13, 2011 01:31 AM
mattrickman
Jun 5, 2008 12:22 PM
