Drive Shaft Lube question
Old Jul 28, 2009 | 09:43 AM
reddevildemo's Avatar
Default Drive Shaft Lube question
I have some Mobil SHC 220 Synthetic grease, would that be good for the U-joints on the front and rear shafts?
Thanks
-Darin
Old Jul 28, 2009 | 09:48 AM
Sure, how many grease fitting are there on the front drive shaft? Has your been rebuilt or replaced yet? Should have 3 grease fitting and one plug on the front shaft and 1 grease fitting and a plug on the rear shaft. Make sure you remove the plug, install a grease fitting lube and reinstall the plug.
Old Jul 28, 2009 | 09:49 AM
jycsalas's Avatar
as long as it meets the requirements of Multipurpose Lithium Base Grease N.L.G.I.
consistency No. 2.
Old Jul 28, 2009 | 09:59 AM
Mike, New Tom Woods installed on front, 4 lube points total counting spline.
jycsalas, It is NLGI 2 Grade Lithium Complex, ISO VG 220.
I can get the tubes for free so it is a huge bonus. Thanks for the responses guys.
DiscoJon
Jul 14, 2019 01:51 PM
caymandrew
May 6, 2013 09:50 AM
nahtanoj
Jul 3, 2012 09:06 AM
LeakyDisco
Sep 19, 2010 03:02 PM
twincharged
Jan 27, 2007 06:48 PM
