gear lube for drive train?
Old Jan 27, 2007 | 01:24 PM
twincharged's Avatar
Default gear lube for drive train?
helloi am going to change my drive train gear lube, on my final drive fornt and rear, and swivel nuckles and transfer case. what wieght gear lube should i use
Old Jan 27, 2007 | 06:46 PM
Default RE: gear lube for drive train?
You should us a gear oil in the 80 to 90W range for the diffs and maybe the t/case depending on the year. You can use this in the swivels also but Rover has come out with a HD grease backet that works even better in the swivels, prolongs wear and doesn't leak as much as regular gear oil.
These packets can be found on line or thru Rover.
Mike
Old Jan 27, 2007 | 06:48 PM
Mike
DiscoJon
Jul 14, 2019 01:51 PM
hubris
Dec 14, 2007 09:31 PM
s2_lwt
Jan 14, 2007 07:41 PM
BridgeRover
May 17, 2005 02:03 AM
Big boy
Mar 25, 2005 10:08 PM
