Drive Shaft Removal (WARNING)
Old Jul 23, 2012 | 11:26 AM
0304Disco's Avatar
Default Drive Shaft Removal (WARNING)
If you are going to be removing you drive shafts, make sure you chock the wheels of your Disco or Auto so the vehicle can not roll.
I found out hard way that this needs to be done and the situation could have not ended so well.
Old Jul 23, 2012 | 11:30 AM
drowssap's Avatar
yes, you are correct if you remove the both at the same time there is nothing to hold the truck.
And you cant use the emergency brake because that works off the drive shaft too.
hope no one was hurt.
Old Jul 23, 2012 | 11:49 AM
0304Disco's Avatar
No one was hurt thank god and no harm was done other than my back for stopping the car from rolling down a hill. I only removed the front and didn't even think that you could use the E brake on the rear. I've read many postings about the removal of the shafts and didn't see anyone mention this nor does it mention it in manual.
Old Jul 23, 2012 | 11:52 AM
drowssap's Avatar
Your say you removed just the front drive shaft and the truck started rolling? That should not have happen the rear shaft should have held the truck.
I meen you can pull either shaft and still drive the truck without one of them , so I dont know why your tranny did not hold in park.
I bet this was the 03 with no CDL?
Old Jul 23, 2012 | 01:21 PM
0304Disco's Avatar
Ah yes, Bitten once again by not having CDL. This should be reason enough to have the wife allow me to complete the upgrade to CDL.
Old Jul 23, 2012 | 03:01 PM
RoverMasterTech's Avatar
Huh? Its an open center diff... If the cdl is OFF and you break 1 axle the car will roll down a hill. If you disconnect 1 prop shaft it will roll down a hill. Just set the E-Brake and you should be fine.
Old Jul 25, 2012 | 01:13 PM
0304Disco's Avatar
Just finished up rebuilding the front Drive Shaft/Prop Shaft. Wow, what a job!!! Getting the orginal joints out is no easy task. That hooks joint is so awkward and moves around every which way working against you. Had to resort to using a cut off wheel to get the joints out. During install, a needle bearing feel out of position and got stuck in the cap and I found this out as I could not get th cap to seat enough to get the C-clip in.
Now for the install and to prey for no vibration. Sure is a lot of work for something that isn't broke. That's preventive maintenance for you!!
DiscoJon
Jul 14, 2019 01:51 PM
Scanner
Sep 28, 2015 11:06 AM
WaldoWilburforce
Dec 24, 2014 09:11 AM
marshman442
Oct 4, 2011 06:45 AM
Hookerpat
Apr 4, 2008 12:25 PM
