Driver door striking pillar
Old Sep 24, 2021 | 06:08 AM
over-land's Avatar
7th Gear
Default Driver door striking pillar
The driver side door on a 04 D2 is striking the pillar.
How do you realign it?
Thanks.
Old Sep 24, 2021 | 07:14 AM
zski128's Avatar
I had this issue and my door hinges where worn. Replaced both of them and all is good now. Grab the bottom edge of the door and pull up. If you feel any play the hinges are done. Got mine from a dismantler.
Old Sep 25, 2021 | 09:29 AM
The_OGCJR's Avatar
If it’s doing this On the b pillar at the top, you would need to adjust the window frame first
look in Rave for window replacement. Forgot which page it is.
there are 2 bolts that you should check if they are tight. One is on the door jam of the door it self and the other is in the door. Towards the front.
tboard24
Mar 24, 2015 12:36 AM
NhudeST
Mar 7, 2012 06:48 PM
zoomlenz4u
Oct 19, 2009 02:25 PM
97vitesse
Jul 1, 2006 10:10 PM
jdmikey
Feb 23, 2006 03:33 AM
