Driver Side Brake Light Out
When the running lights or headlights are on, one of the two filaments in the bulb (top bulb) are lit, though not as bright as the passenger side. when I depress the brake pedal, my driver side brake light goes out. When the running lights or head lights are off and the brake pedal is depressed, it comes on (again, not as bright). I ruled out the bulb. can this be the bulb socket, fuse, or am I missing something else? Funny, was behind another DII a couple months ago with the same problem.
First switch that bulb with the pass side to confirm that it is not the bulb.
Then go to www.roverlandparts.com and buy a new tail light assembly.
For some odd ball reason this is a relatively common problem with DII's, water gets inside the tail light and corrodes the whole thing, eventually it will short out your wiring in the truck and you wont have any lights at all.
It is always the drivers side. I dont know why, but it is.
Let us know how you make out.
Thanks Spike, switched out the bulb with the other side, same problem so not a bulb issue. Then I swapped the whole light assembly. Bingo!! So it's a bad connection in the light assembly. Probably a socket, but I think I'm just going to replace the whole assembly. It collects H2O anyway. Roverland parts is just a couple of miles from my in-laws, which is where we're headed tomorrow, so I will stop in Mon.
I took the light assembly out and removed all the sockets and wiring. I diagrammed the wiring and disconnected all the spliced connections. I then reconnected the wiring (I think it was the blue and brown wires). Plugged it into the truck and it worked. More than likely the problem is the connection of the ground (brown) wire.
No, not much you can do, the seal leaks and then the sockets and wiring corrodes, seems to only only happen on earlier model DII's.
jycsalas
07-18-2009 11:26 PM
BlueDisco
02-19-2007 02:50 AM
