Driver side parking lights no power
This came in the mail today:
was only going to install everything on the driver side to compare to the passenger side, well something went wrong.
the parking lights are not coming on, checked at the plug and no power, the original bulbs work as i have tested them from side to side.
I had installed one of the parking light leds along with the reverse led and the light turned off and now the driver side parking lights wont come on front or back.
all the fuses have continuity, about to check them all one by one.
can you reset the bcm?
BTW the headlight bulb is bright!
headlight
2014 H4 HB2 9003 CREE LED Bulb x1 Hi Low Headlight Kit 2400LUMEN Light Kit 6000K | eBay
Back up light
2X 1156 7506 CREE 5W LED Light Bulbs Backup Tail Reverse Stop Lights White | eBay
Parking Donot buy- this caused my issue
Pair White 1157 BAY15D 10 5630 LED SMD Turn Dual Brake Light Rear Bulb Lamp E056 | eBay
headlight
Back up light
most people gave up and re wired the truck and i did not want to do it, i came across a thread where they pulled the glove box bulb and everything was fine, well that was not the case for me so angrily i pulled the fuse only to have it burn on me on the way out.
replaced it walked passed the front of the truck to grab a drink and i stared at the left and right city lights just glowing...
not sure why it worked but it sure beats calling the indy to have it looked at.
the front has one led light, waiting for the second one to come in to give it a better chance. in the pictures you can see the old bulb better but what i can see is totally different.
the rear locker is on its way along with a new to me tcase-
Did you give up on trying to fix the low range and decide to just get another T-Case?
I left the reverse projector bulbs in, they seem to work fine.
Terheelrover, https://www.facebook.com/piedmontrov...f=ts&ref=br_tf had a sale on tcases, 50% off tcase and it was a deal i couldnt pass up seeing as how locals want 400+
here is his ebay items in TARHEEL ROVER PARTS store on eBay!
i buy stuff from him and northdallasimports when i am not going to the major retailers or junk yards
tibyABv6
12-18-2012 10:09 PM
