Driver side parking lights no power
Old Jul 28, 2014 | 07:40 PM
ls1morethanyou's Avatar
Default Driver side parking lights no power
This came in the mail today:
was only going to install everything on the driver side to compare to the passenger side, well something went wrong.
the parking lights are not coming on, checked at the plug and no power, the original bulbs work as i have tested them from side to side.
I had installed one of the parking light leds along with the reverse led and the light turned off and now the driver side parking lights wont come on front or back.
all the fuses have continuity, about to check them all one by one.
can you reset the bcm?
BTW the headlight bulb is bright!
headlight
2014 H4 HB2 9003 CREE LED Bulb x1 Hi Low Headlight Kit 2400LUMEN Light Kit 6000K | eBay
Back up light
2X 1156 7506 CREE 5W LED Light Bulbs Backup Tail Reverse Stop Lights White | eBay
Parking Donot buy- this caused my issue
Pair White 1157 BAY15D 10 5630 LED SMD Turn Dual Brake Light Rear Bulb Lamp E056 | eBay
Old Jul 28, 2014 | 08:57 PM
license plate light is also out come to find out.
Old Jul 28, 2014 | 09:03 PM
Old Jul 29, 2014 | 11:00 AM
Third brake light is also out - no power to it.
All fuses are good in the cab and in the engine bay.
Cleaned the switch stalk and nothing changed.
Looked through quite a few threads and no answer for the people whom had the same symptoms so I guess to the indy shop it goes.
Old Jul 29, 2014 | 11:55 AM
btw its fixed. i dont like this answer but its what i did.
i pulled the glove box light turned everything on, pulled fuses for city lights and finally 11 blew on the way out.
replaced and everything turns on now.
Old Jul 29, 2014 | 12:13 PM
Jared9220's Avatar
You created and answered your own thread before giving anyone time to chime in. You rock Juan. Did you keep any of the new LED's in? Pics please.
When are you installing the locker?
Old Jul 29, 2014 | 03:11 PM
i have seriously been freaking out about it as all the fuses were good tested 4 times with two different volt meters and visually inspecting them once.
most people gave up and re wired the truck and i did not want to do it, i came across a thread where they pulled the glove box bulb and everything was fine, well that was not the case for me so angrily i pulled the fuse only to have it burn on me on the way out.
replaced it walked passed the front of the truck to grab a drink and i stared at the left and right city lights just glowing...
not sure why it worked but it sure beats calling the indy to have it looked at.
the front has one led light, waiting for the second one to come in to give it a better chance. in the pictures you can see the old bulb better but what i can see is totally different.
the rear locker is on its way along with a new to me tcase-
Old Jul 29, 2014 | 03:28 PM
Jared9220's Avatar
I have heard more than 1 horror story with installing LED lights. I like the look but the one thing my disco doesn't have is an electrical problem and I'd like to keep it that way.
Did you give up on trying to fix the low range and decide to just get another T-Case?
Old Jul 29, 2014 | 04:12 PM
I had read some but figured meh what the heck... well yeah....
I left the reverse projector bulbs in, they seem to work fine.
Terheelrover, https://www.facebook.com/piedmontrov...f=ts&ref=br_tf had a sale on tcases, 50% off tcase and it was a deal i couldnt pass up seeing as how locals want 400+
here is his ebay items in TARHEEL ROVER PARTS store on eBay!
i buy stuff from him and northdallasimports when i am not going to the major retailers or junk yards
Snowdog
Apr 7, 2016 01:05 PM
tibyABv6
Dec 18, 2012 10:09 PM
Classklown90
Aug 24, 2010 04:26 PM
Princess
Sep 15, 2009 08:02 PM
tonyzp007
Jan 26, 2007 11:21 PM
