Driver Window not working
When I bought my Disco II the previous owner said the drivers window needed a new motor, when I took the door panel apart I noticed one of the regulator arms was twister beyond repair so I ordered a new motor with regulator, after fitting both the window still does not move! All other windows work fine, I switched the passenger window switch with the drivers and no issues there, I can hear a clicking come from under the glove box when I press the driver window switch. Anyone have any similar issues like this??
Thanks for suggestions, is there a separate fuse for the driver window? If not, the other doors work fine. As for the relay, same question I guess, is there a separate relay for the driver window?
twoxred
Oct 4, 2021 07:07 AM
tsuyoi
Sep 22, 2020 10:37 AM
