driver's side idler pulley
Old Sep 21, 2015 | 03:12 PM
ge234's Avatar
Default driver's side idler pulley
i've been researching this for a month and cannot find a definitive answer. How many MM is the driver side pulley? 70, 80 or 90?
Old Sep 21, 2015 | 04:17 PM
OverRover's Avatar
PQR101150 is 80mm>>
Land Rover Parts, Accessories and Information
Old Sep 21, 2015 | 04:21 PM
ge234's Avatar
thanks over, i thought so...now hopefully i can find one for a little cheaper than $50!
Old Sep 21, 2015 | 04:38 PM
ge234's Avatar
the tensioner has great tension on it but isn't new by any means...i have heard of putting replacing old idlers with one size bigger to increase tension...wondering if there are opinions of this out there.
Old Sep 21, 2015 | 07:52 PM
ge234's Avatar
is this the correct pulley for the tensioner?
89054
Old Sep 21, 2015 | 10:32 PM
redrover75's Avatar
Default Granger
They have all the bearings and different grades generally in stock.
Old Sep 22, 2015 | 08:58 AM
cappedup's Avatar
The tensioner is spring loaded. Increasing the pulley diameter won't have any effect on the belt tension. The spring is doing that.
You don't want crazy tension. If the belt is in good condition it doesnt need to be guitar string tight to spin stuff.
Full tensioner unit isn't expensive. I would swap the whole thing if you suspect anything. V easy job. Mine had a plastic wheel and was in a terrible state. Bearings were shot. Was scratching it's way around.
MPDano
Jun 15, 2015 09:24 AM
ChanchoVerde
Mar 22, 2010 10:31 AM
mamesteco
Jun 3, 2009 06:02 PM
ChiefII
Mar 11, 2008 10:25 PM
