driveshaft question
Old May 16, 2011 | 04:00 PM
malibutj's Avatar
Default driveshaft question
last owner had new drive shaft 39000 mi ago,,it looks like a stock one ,and only one zerk ,question how many mi should a stock last ,, it was 800 dollors , i no i should upgrade but with what ? thanks
Old May 16, 2011 | 04:13 PM
jafir's Avatar
Just put new u-joints and the centering ball in the one you have. Or better yet, pay someone. Maybe it will come apart easier since it's so new....
Old May 16, 2011 | 04:18 PM
dgi 07's Avatar
You could rebuild it with greaseable u joints. Or you can buy a whole new driveshaft with the zerks already in place. Now some guys rebuild and some just buy the whole assembly. There are alot of threads as to the parts you need to rebuild. I got the kit from toddco suspensions and rebuilt it myself.. Or use the forums search function.
Old May 16, 2011 | 04:37 PM
mwindth's Avatar
malibutj, have you ever re-built a driveshaft before? If not, I'm agreeing with jafir on this one...unless you have a real hunger for punishment, buy 3 new greaseable u-joints, a centering ball kit and call your local driveline shop. They repair/replace drivelines all day long and have the correct tools (blow-torches and what-not) to remove the "bitch" they call a centering ball. Total with parts and labor, $200-$250 tops.
BTW, $800, LOL. If you are writing about buying a new one directly from LR, don't bother, the double cardon will still be ungreaseable.
Old May 16, 2011 | 04:45 PM
malibutj's Avatar
thanks guys just ordered the toddco kit and will take advise and have shop do it these parts will fit the stock drive line ? the 800 dollors is a invoice i found that she had done
Old May 16, 2011 | 04:53 PM
dgi 07's Avatar
Yes it does. The kit works. Did it myself. Will never do it again. And it takes a lot for a mechanic to say that.
Old May 16, 2011 | 04:59 PM
DiscoRover007's Avatar
You should be able to get all the parts for about $50-80 bucks and then you can take it to a shop and they'll likely rebuild and balance it for about $150. Well worth the trouble and peace of mind.
However I'd say your current drive shaft has probably got another 10,000-20,000 miles. But I would seriously seriously not test that because so many things can go wrong on these trucks. Just eliminate it all together and take care of it when you can.
mwindth's Avatar
Do you mean this one? Discovery II front driveshaft repair kit
If so, then yes and no; yes, a centering ball kit is needed. No, because this offer does not provide the 3 greaseable u-joints you will need.
Please read this thread: https://landroverforums.com/forum/ge...rebuild-29302/
Old May 16, 2011 | 05:02 PM
mwindth's Avatar
EXACTLY...take note malibutj...and buy the 3 other greaseable u-joints you will need and call it a day.
Old May 16, 2011 | 05:28 PM
malibutj's Avatar
the kit i ordered is 3 joints and center bearing 99 $ much thanks
