Driveshaft safety loop
Old Mar 25, 2018 | 12:01 PM
Alex_M's Avatar
Default Driveshaft safety loop
Has anyone ever considered adding a driveshaft safety loop to a DECISION to protect the trans? Could be fabbed up cheap. Even universal pre-fab units are cheap. Nice insurance to save the trans from a 4" hole.
Probably will be the next mod on my truck, but curious to see if anyone else has done it.
Old Mar 25, 2018 | 12:47 PM
Twix's Avatar
You could get a steel plate and place it between the trans and the shaft, would be better than a loop for off roading.
Old Mar 25, 2018 | 01:02 PM
Alex_M's Avatar
I'd thought about that at one point, too. I kinda like the thought of the loop though because it would also protect the exhaust and floor pan. That end of the driveshaft doesn't move much either since it's attached to the transfer case which is fixed. I don't think it would interfere much cause it wouldn't have to hang low.
Old Mar 25, 2018 | 02:55 PM
OffroadFrance's Avatar
Hi Alex, yep I designed a front driveshaft restraint hoop some years ago in conjunction with SuperSport on this forum. I never produced it as the usage of the D2 is now minimal after buying a new LR4 (D4) which gets much more use on the autoroutes and locally. In fact it was two hoops 200mm diameter and 150mm apart welded together and anchored in 4 places made from 50x6mm steel flat with 4x 50x6 tie straps and using the same material to make the anchorages. Very easy to remove should the need arise, it would certainly have saved the transmission from terminal damage, that's assuming the driveshaft breaks at the double Cardan which most seem to.
Old Mar 25, 2018 | 07:14 PM
Alex_M's Avatar
That sounds pretty beefy, France. And there's a lot of mass in that double cardon; much less swinging around if the other end breaks, though still a lot. Oddly enough when I had to replace my driveshaft it was the differential end that was making noise. The double cardon was still fine.
None the less, I think I'm going to order this universal fit one and fit it. When I do I'll do a write up at the same time. I'll probably do it on my girlfriend's new ride first since hers is new and the driveshaft is questionable but she has other things to do before replacing the driveshaft. When I get it installed I'll let everyone know how it goes.
Old Mar 26, 2018 | 06:02 AM
JUKE179r's Avatar
This sounds interesting!
Old Mar 26, 2018 | 07:43 AM
LR03NJ's Avatar
The loop wont be able to mount in the front coz the passenger cats is about an inch away to the shaft. Theres is no place to securely bolt the catch.
Old Mar 26, 2018 | 07:49 AM
Alex_M's Avatar
That might be the downfall for installation in a factory truck. We'll see. On mine the cats are moved back past the second crossmember, though the little ladie's is all stock.
Old Mar 27, 2018 | 04:57 AM
Is it possible for anyone to post a photo of the underneath of the V8 front driveshaft showing the general arrangement of the shaft, exhaust and cats, frame etc as I can't estimate the problems involved. It's very difficult to imagine as I haven't owned a V8 D2 for 17 years.
Old Mar 27, 2018 | 06:48 AM
Alex_M's Avatar
I_ll be out at my parents property wherey girlfriend's DEFINITELY is 8n a bit. I'll grab a picture then. I'll also grab a picture of mine to share with the class, and because I need to look and see what I'm working with anyway.
