Drivetrain Whine/Groan Under Power and Cruising
Old Jan 9, 2012 | 07:47 PM
LRScott's Avatar
Default Drivetrain Whine/Groan Under Power and Cruising
I recently acquired a 2000 Disco with 112k on the clock and it makes a groan/whine while accelerating and maintaining speeds above 35mph. It doesn't vibrate or anything, and the noise will go away when I let off the gas, but will return slightly when braking. I've posted a video, let me know what you all think. Thanks in advance!
Land Rover Discovery Whine - YouTube
Old Jan 9, 2012 | 08:24 PM
One place to check may be the transfer case. Many owners have reported reduced noise when replacing T/C fluid with 85W140 (and some say synthetic makes it even quieter), as well as front and rear diffs.
Old Jan 9, 2012 | 08:40 PM
LRScott's Avatar
You nearly read my mind. I was thinking it was the T-case. I'll get on changing the fluid. Hopefully that makes a difference. Thanks!
Old Jan 9, 2012 | 08:49 PM
ebg18t's Avatar
I 'think' my drivetrain seems quieter now that I replaced the fluid in my diff's & transfer case with RP 85w-140. I also did the first of two tranny fluid changes.
Old Jan 9, 2012 | 09:04 PM
LRScott's Avatar
The noise in mine is pretty loud, it would inhibit a conversation. The video does not do it justice unfortunately. The 03 Disco is very quiet, so idk if a fluid change will help... but I have the fluid and pump lying around, so why not try. The 2000 Disco sounds like a Jet engine getting ready to start lol.
Old Jan 10, 2012 | 06:19 AM
tee51397's Avatar
Believe it or not, over-filling can make them noisier. You just want to fill until there's a little trickle. Also make sure the breather is not plugged as a plugged breather will cause a lot of extra noise. If all else fails Motul makes a high Moly reinforced gear oil that may quiet it, I think they may even market it as for noisy gearboxes.
Old Jan 10, 2012 | 01:06 PM
grandkodiak's Avatar
damn my disco never sees above 2k rpm lead foot!
Old Jan 10, 2012 | 02:11 PM
LRScott's Avatar
Everyone is doing about 60mph on that road, you have to hit 3k to get up to speed lest you risk getting rear-ended .
Old Jan 10, 2012 | 09:20 PM
rear ended in jersey = cash for upgrades... state secret, don't let it spread
Old Jan 12, 2012 | 09:55 PM
LRScott's Avatar
Replaced the fluid in both diffs and the t-case with synthetic 75w-140. Still makes a crap ton of noise. Wish I hadn't spent the 70bucks for the fluid... Any other ideas?
