drivng in ice and snow
Old Jan 30, 2010 | 04:29 PM
rphotographer's Avatar
Default drivng in ice and snow
Hello all,
I have a 99 disco II, my question is how is the best gearing in ice and snow??
It seems if I keep it in the regular high, the disco is all over the road is this normal or is there a better way?
How do I set up the right gear package??
Thanks
Ralph
www.ralphduke.com
Old Jan 30, 2010 | 05:12 PM
lipadj46's Avatar
Is your traction control working (is your 3 amigos on)? How are your tires?
Old Jan 30, 2010 | 05:38 PM
You have no choice in "gearing", either hi range or lo range.
Put it in low and your top speed will be 40mph.
Low range wont get you any better traction, only more power to the wheels.
If you are all over the road then you need to slow down and drive accordinally.
Your best bet is to invest in some good tires, either a good set of all terrains or a set of summer tires and then a seprate set of snow tires.
Old Jan 30, 2010 | 06:12 PM
antichrist's Avatar
If you don't want to rely on traction control, put it in 1, 2 or 3, depending on your desired speed. In other words you want to the engine revving a bit higher than normal so that when you let of the throttle you get some engine braking.
In effect you drive an automatic in a similar manner to a manual.
RAJOD
Mar 13, 2015 02:51 PM
supert3d1975
Dec 8, 2014 09:16 PM
boxer826
Jan 2, 2013 09:59 PM
tsuami1
Jan 12, 2011 07:22 PM
Flying Dutchman
Tires
Mar 22, 2008 04:48 AM
