Drivshaft? What is the aweful banging noise?
Old Jul 10, 2017 | 08:54 PM
OverRover's Avatar
Here is a good look at the Tcase output flange nut being waaaaaaaaay out of spec >
Old Jul 10, 2017 | 09:11 PM
cobbcj7's Avatar
Originally Posted by Luckyjayb
Yes there is the fill plug close to the e brake drum that u get with a 1/2" ratchet. That's how you fill and check if the transfer case if full
Oh the Transfer case? I was thinking Torque converter.. Ok, I will check the Transfer Case tomorrow..
What fluid would I use and how do I know if it is full? Is there a way to drain and replace??
Old Jul 10, 2017 | 09:22 PM
OverRover's Avatar
75W-90 Gear Oil
Also useful (just skip to 2:40) > How To Perform Differential, Transfer Case And Axle Service On Discovery 2
Old Jul 10, 2017 | 10:48 PM
Best4x4's Avatar
That sound of the loose nut in that video sure sounds similar to me!
Old Jul 10, 2017 | 11:21 PM
Alex_M's Avatar
Also if you're leaking red fluid, that's transmission fluid and that needs to be addressed too. There's no dipstick to keep an eye on the level and when it gets low enough to be below pickup level... Again, you'll be in for a new transmission.
Old Jul 11, 2017 | 08:31 AM
cobbcj7's Avatar
Does the Torque converter share fluid with transmission? can I keep filling it to maintain it for now?
Old Jul 11, 2017 | 08:36 AM
OverRover's Avatar
I think you mean does the Transfer Case and AT share fluid, and the answer is no. Different fluids as well.
The torque converter is inside the AT.
Old Jul 11, 2017 | 01:46 PM
cobbcj7's Avatar
No, I was meaning, if I have fluid below the torque converter, will it run dry or does it share with the transmission.. I found this answer..
How does the torque converter work?
The torque converter is, essentially, a fluid pump. It shares fluid with the transmission that is pumped outward toward the outside of the torque converter. Inside is the torque converter is an impeller. This impeller is not unlike a small fan that uses centrifugal force to pump the transmission fluid. The impeller faces the turbine of the engine. The faster the turbine spins, the faster the impeller spins and, subsequently, the more torque transferred from the engine to the transmission.
Old Jul 11, 2017 | 02:28 PM
cobbcj7's Avatar
Thumbs up
Here is a good look at the Tcase output flange nut being waaaaaaaaay out of spec > https://www.youtube.com/watch?v=ZH7dxMEgcUk
Thanks for that Idea! I checked and all mine are solid
Old Jul 11, 2017 | 04:00 PM
OverRover's Avatar
Just a headsup, the TC output flange nut should be torqued to 109 ft lbs.
