Droopy Back End on Disco II
2000 Disco II, almost 100K miles, with ACE.
I have noticed recently that when my wife parks her Disco, the passenger rear side of the vehicle sits a lot lower than the rest. Would this be an indication that there is something wrong with the rear air shock system? If so, what do I need to look for to repair this issue? How serious is it?
Thanks,
Thanks,
RE: Droopy Back End on Disco II
Well you can do a search on the forum for this one, it is a very common problem with the SLS.
This will fix the problem forever.
http://www.roverparts.com/Parts/9268D2ABP.cfm
You can take a spary bottle with soapy water and start the truck in the morning and spray all around the air spring and look for leaks.
Could be a loose air fitting, could be a bad airbag.
http://www.roverparts.com/Parts/RKB101200G.cfmgenuine
http://www.roverparts.com/Parts/RKB101200.cfmaftermarket
on
Ken,
If you are at the 80,000 plus range, your bads are starting to leak. You can by replacements from Arnott in Florida for $129 a piece, much less then the dealer, lifetime warranty and a far better design.
If you want more information, PM me and lets talk.
http://www.bmaparts.com/ShopByVehicl...Spring&mode=PA
They have the Arnott Industries for $180 a piece. P/N: ROV082303
