Droopy butt
Old 11-28-2011 | 03:47 PM
hilltoppersx's Avatar
$62 each? thats $128 for two... calibration at the dealer $125. Thats $250. You are only $400 away from a complete +2" terrafirma spring and shock setup.
Old 11-28-2011 | 05:01 PM
jafir's Avatar
Originally Posted by rhyslegge
Anyone out there know how to calibrate without testbook?
I'll let you know. I just sent my hawkeye off for upgrade to version 5 software. Rumors are that it will do it... but not sure. The people on the UK boards also say it will reset ECM and TCM adaptions, and bleed the brakes. We'll see.
Old 11-28-2011 | 08:19 PM
There is a module that you can buy and add to the spring conversion to turn off the SLS warning lamp.
Old 11-28-2011 | 11:04 PM
jafir's Avatar
If converting to springs.... you can just reprogram the SLABS to be coil springs, you don't need any thing special, just have to go see someone with a proper computer. The modules are for the P38 and MKIII Range Rover, which couldn't be ordered without air suspension, so there is no provision to disable it. Even on the LR3, you can disable it with a flash, because some of them came with coils, in some parts of the world.
Old 11-29-2011 | 07:02 AM
drowssap's Avatar
version 5 software will allow you to change your bcm to read coils in place of the sls, and it will bleed your ace system (if equipt) as well as your brakes.
I would not; but if you deside to convert to coils AB kit comes with a down load of some type to convert the bcm to change your settings from SLS to coils, shutting off the lights. So if the they are within a $100 or so of the other guys it might be cheaper using there kit, as you will not need a trip to the dealer to reprogram the bcm.
Old 11-29-2011 | 08:22 AM
jafir's Avatar
Version 4 would do that too... but I never needed it, because my 03 already has coils. I should get the update for 5 soon. I'm pretty excited about the bleeding brakes feature.
Old 11-29-2011 | 07:45 PM
Thank you for clearing that up.
Old 11-29-2011 | 09:34 PM
MrFlea1's Avatar
I took both fill tubes to the left and right air bags and spliced them into a "T" fitting and am now using the connector to keep the pressure. I took the pump and all the parts out and am going to do a rebuild and replace them with NEW air bags. The truck has held a steady height for 2 months now so I think the problem lies inthe lines to and from the air pump.
JumPeR04
09-18-2012 04:16 AM
Newfoundlandrover
06-23-2010 11:34 PM
sloppyjoe
07-24-2009 10:26 AM
KeizerRover
10-27-2008 11:58 AM
TOAD
02-06-2007 09:07 AM
Quick Reply: Droopy butt
