DTC P0741 Lock-up clutch monitoring.
my 2001 Disco2 is not running well sometimes it wont go on gear and it only has one code wich is DTC P0741 torque convertor Lock-up clutch monitoring solenoid stuck open or close. does anyone had the same problem before? i cant find the part number for the solenoid to replace it. car has clean transmision fluid its been service before. the level is correct too. i really need help this time any ideas?
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
ok here it goes... first time i had this issue i went to check codes and try to find out the cause. used google, alldata and asking questions to my mechanic friends. i called the last owner and asked him when did he service the trans last and he said this happend to him exactly same codes and symtoms. he had the trans service and problem went away. this was 6 months ago i just bought this car last month. so i didnt actually check the fluid my self since it was just service. so went under the car and saw red fluid dripping a little. so i started the car and took filling plug out and started putting fluid in trans. it took 4 quarts and a little more. so no rocket scince here. Keep It Simple Stupid i say. now car is fixed no more codes and no more problems
Michael M. Koch
10-22-2012 08:20 PM
