DTC P0741 Lock-up clutch monitoring.
Old Sep 25, 2009 | 02:06 PM
ngv151515's Avatar
Default DTC P0741 Lock-up clutch monitoring.
my 2001 Disco2 is not running well sometimes it wont go on gear and it only has one code wich is DTC P0741 torque convertor Lock-up clutch monitoring solenoid stuck open or close. does anyone had the same problem before? i cant find the part number for the solenoid to replace it. car has clean transmision fluid its been service before. the level is correct too. i really need help this time any ideas?
Old Sep 26, 2009 | 08:54 PM
okdiscoguy's Avatar
These trucks have electronic locking converters that are designed to lock at around 52 MPH. I would drop by a tranny shop.
Old Sep 27, 2009 | 10:46 PM
ngv151515's Avatar
ok here it goes... first time i had this issue i went to check codes and try to find out the cause. used google, alldata and asking questions to my mechanic friends. i called the last owner and asked him when did he service the trans last and he said this happend to him exactly same codes and symtoms. he had the trans service and problem went away. this was 6 months ago i just bought this car last month. so i didnt actually check the fluid my self since it was just service. so went under the car and saw red fluid dripping a little. so i started the car and took filling plug out and started putting fluid in trans. it took 4 quarts and a little more. so no rocket scince here. Keep It Simple Stupid i say. now car is fixed no more codes and no more problems
Old Sep 28, 2009 | 08:39 AM
Might want to consider replacing the filter and ATF again in around a 1000 miles. Since it ran low on fluid, there will be a lot of burned residue that will need to come out so you don't have an early tranny failure from this.
Old Sep 28, 2009 | 09:37 AM
ngv151515's Avatar
i want to do that but like i said there is a leak at the transfer case. red fluid is coming from a rectangular plate (i think) gear oil is leaking from al the way at the top i will clean it all good and recheck.
Old Sep 28, 2009 | 09:55 AM
Are you saying you have ATF leaking from the inspection plate on the t/case, if you you had better change it today before it ruins your t/case, should be a 90W, range gear oil or a 75W/140 for HD use.
Old Sep 28, 2009 | 12:56 PM
ngv151515's Avatar
what is HD use? i will take some pics
Old Sep 28, 2009 | 05:18 PM
HD=heavy duty
The transfer case requires gear lube NOT ATF, just like your engine requires motor oil and NOT AFT.
LI_kidd
Freelander
Feb 7, 2015 09:47 PM
Michael M. Koch
Oct 22, 2012 08:20 PM
fanatic516
Sep 22, 2007 09:38 PM
oncorhynchus
Jan 21, 2007 02:14 PM
agavrilo
Nov 16, 2006 12:19 AM
