Dual Batteries
The only issue with isolators is that there can be a voltage drop across them that will lead to your second battery not getting fully charged. Make sure you check the specs on the isolator. Typically, the technology that makes for a small voltage drop also makes for a high price.
Also, by using a deep cycle battery, you have more use of your capacity because you can more deeply discharge it without damage.
grandkodiak
05-13-2012 05:29 PM
kjj0506
09-03-2007 08:01 PM
