Dual Battery Set upfront...
Old Oct 19, 2019 | 02:55 PM
GoRoll's Avatar
Default Dual Battery Set upfront...
going to set up my deep cycle battery on back until I saw a few photos of people setting them upfront...
do they cut the fender well to fit two?
i looked at mine and there is just no way they’ll fit vertically...
Stuffed my jumper inside the jack since the Jack is useless now.
Old Oct 19, 2019 | 03:03 PM
Bumble's Avatar
Putting two batteries in that location requires installing a tray specially made for it. It’ll also remove the bottle jack area as that entire plastic tray comes out to accommodate it.
Old Oct 19, 2019 | 03:31 PM
gecko951's Avatar
I stressed alot about dual batteries, complexity, cost, etc and then just decided to KISS and buy the biggest battery I could fit in the factory tray.
Old Oct 19, 2019 | 07:34 PM
GoRoll's Avatar
Yes, I took it out and still doesn’t sit flush. I would need to cut the fender well... unless I’m missing something...
Old Oct 19, 2019 | 07:44 PM
GoRoll's Avatar
I’m planning on plugging some A/C stuff. A week long trip in the woods etc without always needing to start the car to charge stuff.
Old Oct 19, 2019 | 08:16 PM
Discorama's Avatar
For that reason I put my second battery into a battery box in the trunk. This way the battery isn't exposed to the high temperatures in the engine compartment. I can take it out for charging or as a power source in the tent or when there is a power blackout at home. Disadvantage is the lost space in the trunk.
Old Oct 19, 2019 | 08:24 PM
GoRoll's Avatar
which is my route as well. I just happen to see this photo...
Old Oct 20, 2019 | 08:52 PM
GoRoll's Avatar
Got a bit bored today so I started with the POS wire. I still haven’t decided which battery and how much AH I will want or need...
but at least the wire is tucked in and hidden all the way to the trunk.
Old Oct 20, 2019 | 09:10 PM
greisinb's Avatar
Are you planning to wire up an isolator or are you just going to run 2 in parallel? I’m planning to do a dual setup with an isolator soon, I’ve built a custom battery tray but haven’t had the opportunity to test it yet to check fitment.
Old Oct 20, 2019 | 09:30 PM
GoRoll's Avatar
Yes, I’ll be adding a VSR. I’m not in a hurry so I’m just taking my sweet time figuring where things needs to be. I still need to build a drawer system on the back but who knows when I can get to it. I’m doing things where my truck isn’t down on weekends since we are always weekendlanding...
