E Drum removal nut ?
Old Feb 16, 2014 | 03:29 PM
parkerlander's Avatar
Default E Drum removal nut ?
Removing tcase> confirming the ebrake drum has to come off>
also confirming nut size as I Do not have it in the toolbox out of the hundreds that I own. Also is it just the nut that comes off or is there more involved? Can not find it in the Rave. Appears to be (1 3/16") ?
Thanks!
Old Feb 16, 2014 | 07:18 PM
Guess all the experts must be busy... :_)
just an FYI its' 30MM or 1 3/16ths.
Once you turn the main Nut and remove , which on mine was torqued and then some , use a few small taps with a rubber mallet and that will allow you to separate the outer shell. Then remove 4 14mm bolts on the interior portion and then you can remove brake drum assembly and repair or in this case hang out of the way.
Old Feb 17, 2014 | 11:36 PM
jfall's Avatar
Can you get a huge crescent wrench onto it?
You will probably need an air tool with a 1/2 inch drive and on the remove impact setting to get it off.
You may need an angle socket adapter too.
Old Feb 18, 2014 | 10:26 AM
there is plenty of room for a big breaker bar and socket. Hit it a few times with the impact then used the bar and it came right off....
Black01D2
Apr 26, 2015 05:35 PM
transpartstech_rover
Mar 2, 2010 02:13 PM
roverboy
Jan 27, 2009 06:37 PM
scubaman
Oct 12, 2008 12:52 AM
