Earth Point
Old Apr 22, 2014 | 08:38 PM
ralphobell's Avatar
What type of usb charger are you using? Did you connect the wires backwards by chance? What are you using for power?
Old Apr 22, 2014 | 08:47 PM
dusty1's Avatar
^, doesn't that just melt the wire and pop the fuse?
Old Apr 22, 2014 | 08:51 PM
ralphobell's Avatar
maybe, maybe not...depends on the size of the fuse and size of cable?
Here is how to test if the voltage is going out your usb charger.
Old Apr 22, 2014 | 08:58 PM
jalodge's Avatar
Old Apr 22, 2014 | 09:02 PM
ralphobell's Avatar
Also make sure your usb charging cable is plugged in all the way. May not be seated enough.
Old Apr 22, 2014 | 09:03 PM
ralphobell's Avatar
Ha..did you read the review on this?
Amazon.com: Customer Reviews: DROK Dual USB Cable Connectors Power Adapter 8-22V 12V to 5V/3A DC Volt Converters Buck Module
Old Apr 22, 2014 | 09:39 PM
jalodge's Avatar
I read it but that is what all of the reviews said for all of the similar devices.
Old Apr 22, 2014 | 10:27 PM
ralphobell's Avatar
I installed this on mine. Took out the drink tray and mounted it above the cigarette lighter. Also installed my oil pressure gauge on the other side.
12V Dual USB Under Dash Mount, 18003W: Auto Body Tools & Auto Equipment : Walmart.com
Old Apr 23, 2014 | 05:55 AM
Ghaniba's Avatar
Originally Posted by jalodge
Thanks for the video, I will check it tomorrow. This is the charger I am using. Amazon.com: DROK Dual USB Cable Connectors Power Adapter 8-22V 12V to 5V/3A DC Volt Converters Buck Module: Electronics
Test it at the battery with a couple of short leads. Might save you from chasing your tail.
Dave
Old Apr 24, 2014 | 04:37 PM
jalodge's Avatar
I tested it from the usb cord and I am getting ~5v and a little under 3A. From what I have read, this is more than enough than what is needed to charge a phone.
