Earth Point
Old Apr 24, 2014 | 04:39 PM
  #21
ralphobell's Avatar
Yes Sir it is doing what it should be doing. So I would think you have an issue with your charging cable possibly. Have another to try?
Old Apr 24, 2014 | 06:09 PM
  #22
jalodge's Avatar
Is there some stupid restriction Apple would put on it to prevent charging?
Old Apr 24, 2014 | 06:23 PM
  #23
ralphobell's Avatar
Do you have a usb power adapter to plug into the cigarette lighter? Test your usb with that and see if the amps are different.
Most iphones require 1 to 2.1 amps. 1 amp is slow charge and 2.1 is a quicker charge. I wouldn't think the 3 amps would be an issue.
Have you tried another cable yet?
Old Apr 24, 2014 | 06:52 PM
  #24
jalodge's Avatar
I tried it on a Galaxy Tablet but it still doesn't charge. When I plug it in, the tablet recognizes the charger but puts a red X through the lighting bolt and when I go to settings it says it is not charging. Could 3A be too much?
Old Apr 24, 2014 | 07:24 PM
  #25
ralphobell's Avatar
What size fuse did you use?
Old Apr 24, 2014 | 07:29 PM
  #26
jalodge's Avatar
I used a 5A fuse with the fuse wire tap that was recommended.
Old Apr 24, 2014 | 07:48 PM
  #27
ralphobell's Avatar
I would change the fuse to a 3 AMP and see if that makes a difference.
Old May 2, 2014 | 06:54 PM
  #28
jalodge's Avatar
I tried this but got the same result. Do I need some sort of resistor to cut down on the amps or should I just take out the charging ports?
Old May 2, 2014 | 10:03 PM
  #29
ralphobell's Avatar
I don't know....not sure why it would not be working. I did notice the reviews on Amaznon complained about it not charging as well.
antichrist
Mar 29, 2011 08:41 PM
Brokenrover
Jul 21, 2010 05:27 PM
matthew527
May 8, 2009 02:11 AM
traffictech870
Mar 23, 2005 11:45 PM
