Easy Question
Easy Question
I just picked up a 95 Disco and have yet to put it into 4WD. The problem I am having is knowing how to do it. I tried it in park with the brake on but it is not going into to either Hi or Low (I didnt want to force anything). I would read the owners manual but I do not have one and the placard is missing from the center console.
Thanks in advance!
Thanks in advance!
on
RE: Easy Question
The t/case shifts like an H.
While the tranny is in N move the t/case shifter to the left, High Lock is left and low, Low Lock is left anf up.
If you levae the t/case shifter where it is right no you will be in an unlock High range, if you push the shifter all the way forward you will be in unlocked Low.
Mike
Mike
Brad S1
09-08-2008 09:43 PM
