Easy Question
Old Aug 4, 2006 | 08:06 PM
dmonares's Avatar
Default Easy Question
I just picked up a 95 Disco and have yet to put it into 4WD. The problem I am having is knowing how to do it. I tried it in park with the brake on but it is not going into to either Hi or Low (I didnt want to force anything). I would read the owners manual but I do not have one and the placard is missing from the center console.
Thanks in advance!
Old Aug 4, 2006 | 09:10 PM
Default RE: Easy Question
The t/case shifts like an H.
While the tranny is in N move the t/case shifter to the left, High Lock is left and low, Low Lock is left anf up.
If you levae the t/case shifter where it is right no you will be in an unlock High range, if you push the shifter all the way forward you will be in unlocked Low.
Mike
Old Aug 5, 2006 | 12:51 AM
dmonares's Avatar
Do Disco's come in full time AWD and 2WD-4WD? My Disco is always in AWD and I can only shift the transfer case from Hi to Lo.
*Nevermind, I found out they are full time AWD.
Old Aug 5, 2006 | 10:04 AM
Landzu's Avatar
You have a high and low open (not locked) and you have a
high and low locked, that is when you get a 50% front and 50% rear power to the wheels.
Never use the locked transfer case high or low on the road you will not have the
transfer case long that way.
Old Aug 7, 2006 | 01:30 AM
dmonares's Avatar
thanks, I cant even get it into Hi or Lo locked, just Hi or Lo Unlocked.
Brad S1
Sep 8, 2008 09:43 PM
cptshanman
Aug 16, 2008 09:07 AM
72chevy
May 8, 2008 09:04 PM
96SE7Disco
Feb 1, 2008 04:21 PM
Camdisco24
Oct 3, 2007 09:40 PM
