Easy question...I think
Old Jun 27, 2012 | 09:13 AM
raul507's Avatar
Default Easy question...I think
I'm replacing an AC hose on my 2003 Disco and just need a little insight on one thing. I have to remove the air cleaner assembly and was wondering exactly how it's attached. I checked the RAVE and it states to just remove the assembly from three grommets....
Anyone know if it's just an easy pull and replace or do I need to go under the front left fender and remove something from the bottom. Thanks.
Old Jun 27, 2012 | 01:37 PM
kc disco guy's Avatar
Banned
https://landroverforums.com/forum/di...removal-49235/
follow this link its step for step!
Old Jun 27, 2012 | 01:55 PM
Bkreutz's Avatar
Sometimes the rubber grommets come out with the airbox, just take them off and reinstall. It's also a good idea to put some lube (petroleum jelly, lithium, spit) when you reinstall it or you could push the grommets out onto the ground when you push down on the box
Old Jun 27, 2012 | 02:23 PM
raul507's Avatar
Exactly what I was looking for. Once again saved by the forum. Much appreciated guys.
Old Jun 27, 2012 | 02:47 PM
jfall's Avatar
Just unclip the clips around the air cleaner box.
Unclip the two clips at the round area.
If you are removing the MAF and tube, take off both hose clamps.
One on the manifold and one at the end of the MAF.
Taking the MAF plug out - don't damage it.
Old Jun 27, 2012 | 03:19 PM
So, once you remove the old hose and install the new one, are you aware you have to pump down the system before installing oil and freon?
Old Jun 27, 2012 | 04:04 PM
raul507's Avatar
Yeah Mike I'm aware...thanks for checking though. I've already evac'd the system prior to swapping out the AC line. Will probably have the shop charge the system....just wanted to save the 200 bucks to swap out the hoses.
Old Jun 27, 2012 | 04:06 PM
I hear that, just makes sure the shop puts in the proper amount of freon and oil and the sticker under the hood recommends
Old Jun 28, 2012 | 09:11 AM
raul507's Avatar
Thanks again Mike. I appreciate the heads up!
lipadj46
Aug 19, 2009 06:11 PM
72chevy
May 8, 2008 09:04 PM
96SE7Disco
Feb 1, 2008 04:21 PM
Camdisco24
Oct 3, 2007 09:40 PM
dmonares
Aug 7, 2006 01:30 AM
