Easy Rear Sunroof Motor Replacement
Old Jul 20, 2013 | 03:31 PM
srockrae's Avatar
Default Easy Rear Sunroof Motor Replacement
Just FYI, for those wanting to swap out the motor on the rear sunroof in a Disco II you do not have to remove Headliner. Just remove switches and the one headliner retaining screw and the sunroof trim peice then you will have plenty of room to remove the three torx screws and swap it out. It helps to have the torx on a small ratchet versus a short screwdriver. Took less than 30 minutes.
alti
May 9, 2013 11:55 AM
BigRed98
Jun 21, 2010 12:30 AM
ryant06
Mar 28, 2008 09:01 PM
alanroberts50
Nov 18, 2007 11:56 AM
lrd99
Jul 18, 2007 08:18 PM
