ECU Air Temperature Control Unit Lights
Old Nov 21, 2011 | 08:05 PM
04BluDisco's Avatar
Default ECU Air Temperature Control Unit Lights
Hi, I had the light go out on the driver temp control on the Air Temp Control Unit (ECU). All other bulbs that backlit the control were working, except that one. I pulled the whole unit to access the instruments bulbs, (pulled the radio to access the clips that hold the unit in place) and when I put the unit back in, no light worked. The unit worked fine, but even after checking all the connections multiple times, still nothing.
Anyone know of a trick on the lights? A bit frustrating...
(and yes, I did look through the forum with nothing fitting this description)
Also, for those of you looking to remove the radio head unit, I took a hacksaw blade and cut it lengthwise with some tin snips (amazingly easy, I might add). Basically, I took the width of the blade down by half and cut it back 3 or 4 inches... Makes a great tool for the removal of the radio. (pict attached)
And, importantly, you don't have to listen to the jackasses as the stereo stores tell you that it's a specialized $60 part because it's a land rover... yeah, it's a half of a broken hacksaw blade...
Old Nov 27, 2011 | 09:15 PM
04BluDisco's Avatar
nothing? anyone had issue with this in the past?
Old Nov 27, 2011 | 09:32 PM
pins 4 & 5 on this connector provide the light circuit.
File Type: pdf
File Type: pdf
Rover Cabo
Mar 3, 2015 07:10 PM
outdoor7or24
Sep 6, 2012 10:32 PM
Mike MacDonald
Aug 29, 2012 07:53 AM
dgilson4
Oct 25, 2011 11:26 AM
Arsenal 1
Mar 27, 2010 04:47 PM
