ECU & Instrument Cluster Replacement
muffin man (03-23-2022)
on
if it is only to install and put again in another truck exactly the same, I have simply been informed that you only have to wait 20 minutes for the IDM to be configured (in case the complete fuse box is not changed too)
I've never had the IC, & BCU ever sync up by leaving the key on. With a Nanocom you can sync a lower mileage cluster to the BCU or vise versa & it will go with whatever unit has the higher mileage. You can also simply just turn off the ODO flashing via Nanocom as well without syncing anything.
Jst4fun
10-20-2017 09:52 AM
